Starting my first build
21 Jan 2012
UK
Hi guys, I have just been introduced to building desktops and this website and have many questions regarding my first build. Ideally like to purchase all components from Ocuk. To start off I am looking at the NXZT Phantom 410. Watched some reviews and it seems to be a solid case with a lot of options. Anyone have any personal opinions on the case and the company? Also will I need any additional parts to add to the case to replace stock parts e.g if the fans don't come with dust filters. I also liked the cooler master nvidia editions but can't seem to find any to buy (for a decent price).
I will have many questions as I progress xD
With the cases its more down to personal prefence of size/colour/design although you may feel abit stupid if you end up getting an ati gpu in a nvidia case.:p
NXZT make decent quality cases although the looks aren't to my taste. I can think of plenty of cases i'd go for ahead of this one. Cases are subjective though.
I quite like the look of it. It seems to have plenty of space inside too and I don't really have the room for a larger full tower...even though this one is still quite big. I will probably be looking to get the gaming bundle from here, but not too sure whether I should go for the i5 or the amd bundle and what sort of power supply I'll need.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-080-OE&groupid=43&catid=2053&subcat=2063 +8GB upgrade
Or
http://www.overclockers.co.uk/showproduct.php?prodid=BU-085-OE&groupid=43&catid=2053&subcat=2067
I would like to go for a corsair psu
will probably be running single gpu to start but may add another as time goes on. Might invest in the
http://www.overclockers.co.uk/showproduct.php?prodid=CA-038-CS
or maybe
http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-CS&tool=3
not too sure which would be best. Inr egards to internal hard drives I was considering
http://www.overclockers.co.uk/showproduct.php?prodid=HD-244-SE&groupid=701&catid=14&subcat=1955
When it comes to cooling I will probably stick with fans and sinks for now...are stock fans worth replacing straight away or should I just add more?
as for graphics, I am aiming for around the £150-200 mark for the card. On a quick initial look these were my choices
http://www.overclockers.co.uk/showproduct.php?prodid=GX-114-MS&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=GX-145-GW&tool=3 - from the reviews this seems to be quite a small and quiet card so may not have to remove any bays from the case to get it to fit.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-043-ZT&groupid=701&catid=1914&subcat=1341
Do this,
Either get the cheapest GTX560ti, or get a 2GB version - http://www.overclockers.co.uk/showproduct.php?prodid=GX-153-EA&groupid=701&catid=1914&subcat=1341
May start off with the cheapest GTX560 and then sli a bit further down the line. Is there ny benefit in doing this over getting a single 2GB gpu?
You need to ensure you get a SLI compatible motherboard first, the Gigabyte AP-D3 only does Crossfire.
Easier to stick with a single GFX card.
They are great cards. Consider this one:
The 2GB of VRAM will help with recent games and probably future games too.
Also a 6950 is slightly better:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-042-HS&groupid=701&catid=56&subcat=1752
Comparison:
http://www.anandtech.com/bench/Product/293?vs=330
All this being said, nothing wrong with your choices!
In regards to the ATI card...it seems like a large card, would it fit in the NZXT phantom with or without bay removal?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-035-NX&groupid=701&catid=7&subcat=35
Okay so on my list so far is
NZXT Phantom 410 Midi Tower - http://www.overclockers.co.uk/showproduct.php?prodid=CA-035-NX&groupid=701&catid=7&subcat=35
EVGA GeForce GTX 560Ti 2048MB GDDR5 Graphics Card - http://www.overclockers.co.uk/showproduct.php?prodid=GX-153-EA&tool=3
Samsung Blueray Player - http://www.overclockers.co.uk/showproduct.php?prodid=CD-138-SA&groupid=701&catid=10&subcat=314
XFX 650W XXX Edition Modular '80 Plus Bronze' Power Supply - http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XF
Krypton Z68 590i Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle + 8GB - http://www.overclockers.co.uk/showproduct.php?prodid=BU-080-OE&groupid=43&catid=2053&subcat=2063
Samsung SpinPoint F3 500GB HD - http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA&groupid=701&catid=14&subcat=940
This is what I've got so far...if anyone can see any problems or if stuff isnt compatable or maybe if I need a 650w psu let me know xD any advice on additions or changes is welcome!
