Starting problem :-(
10 Jun 2003
I went to switch on the PC and all the fans did one revolution and wouldn't start. If I repeatedly press the power button fast I can get the fans spinning but it still won't start :mad:
I seem to be getting power to the mobo as the fans wouldn't start otherwise ? The PSU lights up but doesn't start as does the mobo :confused:
Mobo is a DFI Lanparty , PSU is a OCZ Gamestream 600W , Case is a Lian Li PC7 Trying to pin down what the problem is
Dodgy case switch ?
Goosed mobo ?
Knackered PSU ?
Has anyone else had this happen or have any ideas ?
Is the system overclocked at all?
If so, has it been stability tested?
Try loading default settings in the BIOS and see if the system will POST.
