Startup issue.
f2t
f2t
1 Aug 2010
When I power on my pc that I have just built (with some good advice from the overclockers forum :) ) it starts whiring and the fans come on for ~1sec then seems to turn off, it then starts up properly about 10 secs later.
Ive not put an os on yet so its just going into the bios if that makes a difference.
Is this normal?
here is the spec:
# Radon Intel Core i5 760 2.80GHz @ 4.00GHz Overclocked Bundle
# Antec 300 Three Hundred Ultimate Gaming Case - Black
# Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black)
# Corsair TX 650W ATX SLi Compliant Power Supply
# Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM
post in the RMA/Return & Technical Queries forum, i think the overclock is a little short on voltage for cpu or memory.
but they should be able to get you to check the settings, as i think they supply bios entries for overclocked settings and default settings.
