- 10 Sep 2008
- Macclesfield, U.K.
hi guys.
Basically my friend has moved into a flat and he wont have internet for another month.
All of his games are on steam.
He goes to play on 'offline mode' and it says you cant do that.
I looked into it and basically the only way you can go into offline mode is to be connected to the internet and tell it to start in off line mode, but only if your connected to the net.
He has auto sign in on and you cant open steam up to turn this off unless you log in first and then turn it off, which is the other way to go offline mode...
Just wanted to point out how much of a useless feature this is, unless you set up before hand. I can imagine this really messing up a LAN party.
Any of you had this problem/know of a fix i havnt found?
