- 21 Jun 2011
Hello.
I know how (sort of) to split the STEAM install between two drives - I have done so using GameSaveManager to automate the process a tad. I know it, but I don't truly understand it, hence this thread.
Current setup:
Main steam install (executable and nearly all installed games) is on hard drive.
Folder symlink to Oblivion install on SSD (nearly 15Gb... ouch) for faster loading/less stuttering. Works fine - Steam still sees it (does not try to reinstall, runs fine etc)
It is a -little- faster than just having Oblivion on HDD, but not as fast as I was hoping.
Question - Should I reverse this? Is the current setup causing Oblivion to seek on the HDD, follow the link and then seek on the SSD, thereby bottlenecking the SSD?
I'm asking rather than trying because I think it would be an ENORMOUS pain to actually reverse the install - I'd have to manually make links to every directory in my steamgames folder, right, not just the top-most layer?
thanks to anyone making sense of this.
Current setup:
