steel series apex 7 keyboard problem after update
15 Sep 2006
Edinburgh
hey guys i had a update for the steel series software earlier and afterwards i noticed my lcd screen on the keyboard had stopped displaying the system monitor info, eg temps and usage.
i went into the software and the apps section and i see no sign of the system monitor app i was using on it before, it is like it has been removed but no mention of it and i tried a factory reset of my keyboard but no luck.
any one else having the same issue or just me?
Had a look on line about this and it has happened to a few people, they also had no luck with resetting the keyboard.
I wonder if you contact Steel Series they would release another update to fix the issue.
thanks, i was geting worried it was just me :)
new problem now, its not detecting my 7800x3d but detecting my ram and gpu, have they fixed it yet? all it says on my cpu bit is cpu: unknown and NaN ghz wtf......
just got the latest cpu z and that detects it properly no idea wtf is going on since i have keyboard updates disabled.
