Steelseries Siberia replacement extension cable
28 Oct 2010
Glasgow, Scotland
So my extension cable for my Siberia headset broke. The headphones themselves are fine so I need to try and buy a replacement extension cable. The extension cable they came with supports both the audio 3.5mm and also the mic.
Does anybody know if you can buy a direct steelseries replacement cable for this? I couldn't find one on their site.
Are there any alternatives? Something that supports both the audio and mic and then runs into the one cable and then splits again at the end? I would rather not have two separate cables it would be better if it was one splitting at both ends.
Thanks
