Thanks mate... yeah i used to think it was the PSU before i bought the overclock bundle.....I bought it as part of a whole system from Mesh, the system came to about 1600 overall at the time.
I did think it would be okay though since the PSU is 950 watts which should be enough but its about 3 years old now so it could be a little faulty.
What would you reccommend then if i decide to get a new PSU
Also i know the MB isnt the best for crossfire as one card runs at x16 and the other only runs at x4. Ill eventually be going to a single card solution but at the moment i just want to try and fix this issue.
950 watts should be fine shouldnt it...but like you said if its not a good brand or its a cheap one then it could be that which is causing the issues.
