Here's my problem.
I have a CM Hyper 412S cooler on an Asus Sabertooth Motherboard.
That cooler overhangs DIMM 1 and 2, there is only just enough room to fit low profile RAM modules, there is about 5mm head room once fitted.
I'm looking to upgrade my Memory to 2x 4GB; PC3-2130 (2133Mhz)
The problem is you don't seem to stock such modules in low profile format.
If you had these CML8GX3M2A2133C11B In stock i would buy them from you, a competing retailer does, so despite the fact that i would prefer to buy them here i'm forced to go there.
I'm pretty sure i'm not alone in needing low profile Memory modules.
See pic for what i'm talking about, you can see the black modules under the cooler.
Thanks
http://www.corsair.com/us/memory/am...annel-ddr3-memory-kit-cml8gx3m2a2133c11b.html
Thanks
I'd go for the 16GB 1866MHz kit if you are looking to be 'greedy' as you will actually notice the difference (16GB of RAM instead of 8GB
