24 Sep 2015 at 16:06 #1 Furyus Furyus Associate Joined 15 Sep 2010 Posts 1,027 Location Weston-super-Mare Guys what HDD would you recommend for a internal storage? Not SSD thanks.
24 Sep 2015 at 16:10 #2 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,279 i would go for a WD Drive. whats your budget and required size of the HDD?
24 Sep 2015 at 18:26 #3 Furyus Furyus Associate OP Joined 15 Sep 2010 Posts 1,027 Location Weston-super-Mare ED209 said: i would go for a WD Drive. whats your budget and required size of the HDD? Click to expand... 1-2TB would be fine, budget not sure yet..
24 Sep 2015 at 19:04 #4 thebennyboy thebennyboy Soldato Joined 23 Dec 2013 Posts 3,549 Location North Wales Is speed or silence more important to you? Are you going to use it to store games?
24 Sep 2015 at 21:18 #5 Furyus Furyus Associate OP Joined 15 Sep 2010 Posts 1,027 Location Weston-super-Mare thebennyboy said: Is speed or silence more important to you? Are you going to use it to store games? Click to expand... No speed isn't but silence is, I opted for the WD Green Caviar in the end. Did abit of research and think it would be the best for what I need. I will be building NAS down the line, But I'll fill those with WD Reds. thank you
24 Sep 2015 at 21:45 #6 thebennyboy thebennyboy Soldato Joined 23 Dec 2013 Posts 3,549 Location North Wales Furyus said: I opted for the WD Green Caviar in the end. Click to expand... Great choice.
25 Sep 2015 at 11:18 #7 bledd bledd Don Joined 21 Oct 2002 Posts 46,877 Location Parts Unknown Remember to buy two of them. One for the data, the second for the backup of that data. Because of course you keep backups
