Storm Scout - cable management
10 Jan 2010
Reading
Been meaning to pop open my scout case and do some cable work with it, it's not terrible but it's not good..would help if there were holes on the side of mobo tray.
So for those who have got a scout, can you post some pictures up of the inside of case please? Can then get an idea of where to start!
:D
Thxs
I havn't got any pictures but iirc most of my cables are just tucked behind the mb tray as much as possible, with spare sata power and data cables tucked under the HDD's. I also used the metal clips that are built into the case to hold the rear extract fan cable to hold the cpu power cable tidily.
