strange 15pin d-sub cable
4 Jan 2004
Nottingham
hey guys, ive just found a wierd vga cable in a box of wires i have.
its got a 9-pin din connector on one end eith a small cut out (the kind you have on your g-card that provides s-video and composite out, infact exactly the same size i think) and on the other there is a 15pin d-sub connector (vga)
any one have any ideas if it'd work if i connected it up to a g-card and monitor?
ok here are a few pics
yeah i tried googling too but couldnt find anythin. do ya think it would cause any harm to anythin if he tried it?
lol i love my 7000!!!
i might try it later, just as long as it dont destroy any of my monitors
the closest i could find on google was an actual s-video to vga cable
but its not actually an s-video cable on the end?? s-video is a 4-pin din of sorts. this ones a 9-pin din that you find on g-cards that is usually a multi out/in. i.e. splits off to composite and s-video in and out for VIVO cards or just composite and s-video out for other cards
yes i had one end like that on my holywood + mpeg card for dvd's and video before videocard did it in hardware around the 3dfx days and other end of lead was yellow and orange and a s-video out
