strange - audio question
8 Mar 2003
UK
is there a way i can play audo direct through my mic?
i.e so i can use audio clips it on skype and voip
i've tried a loop in from the audio out to the headset but it's a bit loud an poor quality
This may sound like a stupid response, but why would you want to play it through a mic?
Technically you can make a mic work like a speaker, but if you don't like what the speakers are giving you allready you won't be pleased by the mic - just look at the size of the diaphram on it.
I think that perhaps I'm not understaning quite what you're asking!?
EDIT - Do you mean "can I loop audio out and directly into the input of the skype/VoIP device?" - I'm sure that can be done, but it may require some mixing...
it depends on what sound card you have.
If you have a creative, then set it to 'what u hear' or stereo mix if you dont in the recording bit of sounds and audio devices
Just change the input (recording) device.
Dead easy to do, i use soundboards on teamspeak (switching the input device) for a laugh sometimes.
