strange datagrid issue
18 Oct 2002
Derby
Is there any reason why having a more than one datagrid on a page cause weird results? I have a simple page which lists employees in three departments. I have department 1 as userid 1-20 then department 2 as userid 21-30 and have the queries in sql. My code is set out like this:
Code:
void Page_Load()
        GetCommercialServices();
        GetPrivateServices();
    void GetCommercialServices()
            OdbcConnection DataConnection = new OdbcConnection(ConnectionString);
            QueryString = "SELECT (([SOLICITOR].[SolicitorID] >= 12) AND ([SOLICITOR].[SolicitorID] <= 22))";
            DataConnection.Open();
            DataCommand.CommandText = QueryString;
            DataCommand.Connection = DataConnection;
            DataAdapter.SelectCommand = DataCommand;
            DataAdapter.Fill(dataSet);
            GetCommercialClient.DataSource = dataSet;
            GetCommercialClient.DataBind();
    void GetPrivateServices()
            QueryString = "(([SOLICITOR].[SolicitorID] >= 23) AND ([SOLICITOR].[SolicitorID] <= 25))";
            GetPrivateClient.DataSource = dataSet;
            GetPrivateClient.DataBind();
If I just invoke department 1 I get a correct output like so:
Dave Smith
John Smith
If I just invoke department 2 I get a correct output like so:
Kevin Taylor
Steven Taylor
If I invoke both methods I get the first datagrid ok, but the second one is the two datagrids combined. Is there any explanation for this madness?
Note: I have made the sql statments shorter.
Code:
void Page_Load()
Dave Smith
John Smith
Kevin Taylor
Steven Taylor
Hard to say to be sure, but if the dataSet object is global then arent you filling it with the first set of data and then filling it with the second set of data?
Dont you need two distinct dataSets?
