hey guys, I recently upgraded my pc, my current rig is:
Q6600@Stock
8600GT@Overclocked
250 Seagate Barracuda
I recently changed the CPU from a AMD 3800X2 to the Q6600, and a 250gb western digital to the barracuda.
Onto the tests: The thing i found most strange was, when it came to the two CPU Tests i got between 1 - 2 frames per second.. yes.. between 1 and 2! Then onto the other tests, With AMD rig i was getting way higher fps than i'm getting now, on the first test [the sci-fi shooter] my lowest is 9fps to 40 [in corners]. I understand my 8600GT isn't amazing but it it shouldn't be getting 9 frames should it? Also in the test where you have the "airship" and the lochness sort of dragon creature, I also got frames of 10 [lowest] to around 40 once again. Now i'm positive on my old AMD i was getting way higher.
It's all confusing, sorry if it doesn't make sense, i don't understand it myself. Oh and when i was submitting my results it mentioned i needed the futuremark drivers?
At the end of the tests my score was 6697, now i'm guessing that's bad from the frames i was getting.
If anyone has any ideas what's wrong, or any comments please post them.
Thanks
Joe.
Q6600@Stock
8600GT@Overclocked
Thanks
Joe.
