Hey there, I just recently bought an r9 290 and due to its length, had to take out the metal HDD casing in my CoolerMaster Haf 912+ (which my HDD drive was positioned in) and transferred it to the lower cage.
http://images.bit-tech.net/content_...912-plus-review/Cooler-Master-HAF-912-8-l.jpg
I just took out the middle hdd case thing on the right and put the hdd in the one below
I initially thought there was a problem with the card because it wasnt being detected and my computer started really slow and then froze on the desktop. I think there was a buzzing sound too, maybe the psu? mine is 850watts
I started it again (slow startup, also the grinding noise was ridiculous and constant for 3-5 minutes). I managed to isntall up to date drivers which fixed the graphics card issued but again the grinding noise persists everytime I boot up, also the startup time is extended. It sounds similiar to this, but a bit more screechy https://www.youtube.com/watch?v=J09pWNQPK7U#t=12 .
However the noise calms down after 10-15 minutes and shifts from a constant grinding (mostly) to a quick jitter/grind every few seconds for a moment. I am use to this to some degree but this seems much more frequent and louder.
I ran HD tune and did an error scan and everything is ok.
My HDD is the TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm).
Is this is a sign of a failing hdd ? perhaps I didnt isntall it correctly?
