- 25 Nov 2006
- Ipswich, Suffolk
Hi,
Got a slight concern with my PC.
It's fairly old (P4 3ghz HT, Gigabyte Springdale board, 1GB DDR Ram, 9800pro and an Antec Trueblue 480w PSU).
I switch the power off at the mains every night when I'm finished with the PC. The next day when I get home from work I switch the power on at the mains and all the lights on my case fans light up and start to spin, but only for a second. Then I turn the power on at the front of the case and off I go.
Is this anything to be concerned about? I've tried using the switch on the back of the PSU as well and I've tried a different surge protector that all my PC equipment is plugged into and it still does it.
Should I just be leaving the mains on while I'm not using it?
Thanks
Thanks
