- 26 Jan 2018
- South
Hi all,
I'm genuinely puzzled with this one so hoping someone can help....
I have a high pitched sort of bearing noise that I get on a cold start, on cold days, which goes up and down with revs but disappears completely if I press the clutch pedal in. The noise does not happen when the engine is hot, or on a warmer days at all.
The noise also stops after about 30 seconds or so when everything has warmed up, sometimes lasts a bit longer.
You'll need volume up to hear it.
First thought - Release bearing but surely I'd only get that noise with the clutch pedal pressed in, not with it released?
Second thought - Input shaft bearing, though after speaking with a master tech at Volvo they told me they've never seen or heard of it before on this gearbox (M66), it's bulletproof apparently.
I noticed yesterday if I drop from 2nd to 1st again after initially pulling away I'll get it as well.
Car is a 2007 Volvo S40 T5 with 101,000 miles.
Thanks!
Thanks!
