Strange problem - computer just won't start.
22 Jan 2012
I've been having this odd problem on and off for quite a long time, but the past couple of weeks its stepped up to being almost every day. On boot up the computer seems to be loading fine; all fans spin up, lights come on, hard disk spins... but nothing appears on the monitor and it just displays no signal.
The PSU is new, and is of ample wattage, so I've ruled that out. The main issue seems to be with the RAM and/or MOBO. Everytime i've managed to get the computer to boot its been after re-seating/swapping around the RAM, but using the same RAM sticks. At first i thought they were just loose, as it seemed to work for a week or so with no problems. However, now its happening daily, when i come to turn on my computer in the morning: nothing, and i go through the whole process of messing around again. Yesterday I took the RAM out, swapped it around, left one stick in and eventually got it it to boot, so i Re-set the bios, did a win7 memory test and all seemed fine... so i took that stick out and replaced it with the other, did the same again and it was fine. So i put them both back in - no problems for the rest of the day. So i figured maybe it was bios related.... but no, today it did it again. I took one stick out, booted, nothing.. took both out, stuck the other one in and it worked.
So today i'm just running on 2Gb, yet im sure tomorrow it'll stop working again, and that if i were to put the other stick in it would also work (i'd rather just not risk shutting it down again right now)
so i'm completely stumped! Both RAM modules tested fine, and often seem to run fine... could it be a dodgy motherboard?
thanks for any help!
Specs:
MSI P965 NEO-F
4Gb DDR2 PC6400
ATI Radion 5770HD 512mb
Core 2 Duo E6600 2.4Ghz
Managed to give both modules two passes each independently of each other... First with the one that i put in this morning to get it working, and then after two passes I swapped it with the other one to test them both independently and they both pass with no errors.
The only thing i did notice was that each module was very hot when i swapped them over, but i don't see how this could be affecting it starting on from a cold boot.
I guess this must point to a motherboard issue?
Give the latest Bios a go, if memtest says the ram is ok, then you can pretty much rule that out. Is the RAM 100% compatible with the motherboard? Check the Ram QVL list for your motherboard on MSI's website. I had this issue with my previous mobo.
All volts correct? In particular, the Ram volts?
It could be the mobo itself unfortunately.
I run a PC repairshop and I have had faulty RAM in that has passed memtest with no errors before, the ram was factory installed in a laptop by the way so I don't think compatability would have been the issue here.
Although to be fair if it passes memtest it *should* be ok.
