Strange problem with a R290
20 Oct 2013
S.Wales
So i bought a powercolor R290 PCS+ and have had a few teething problems, first off i could not get the 14.1 drivers to work, then i tried 13.2 all was fine, i installed MSI AB so i could monitor the temps and fps, as i have mentioned in a few related threads my card was quiet loud when doing a maxed out heaven run, yet gibbo has claim that his findings is a cool and quiet card, now to cut a long story short, i have notice after a restart, if i go in to MSI AB my voltage control is on plus 50 at the start and i have to click on the rest tab for it to run default setting, i have not had MSI AB on this PC before, i have always used Evga Precision, and i have never saved any profiles with that as you could not adjust the volts on my 780 or 780ti so other than some sort of bug is there any other plausible explanation for this, if i never had MSI installed would this still happen?
Since resetting my card is now running cooler and quieter and bearable, but i have to reset after every restart :confused:
Which version of Afterburner are you using. It should be the v3 beta 18. Even if you are and this is introducing problems, you may just have to accept that it's an unfinished beta and uninstall Afterburner.
taz007 did u manage to sell ur 780ti? i messaged you on thebay about it but got a new palit jetstream 780ti for £410
