Strange problem with my X800 XT PE
19 Mar 2007
Hi all,
I searched high and low and couldn't find an answer to this.
I have a very intermittant issue with my X800, sometimes it just offers no display when trying to post. A quick reseat fixes it, then 6 reboots later it won't work again.
Has anyone experienced this before?
The board i am using is an Asus A8V Deluxe (939).
Many thanks in advance
Si
RaiderX said:
have you checked it is in tight and screwed in? it might be a loose connection on the motherboard
Yep everything is firmly built in, it's really strange as once you reseat it, its ok for a while..
Could it be dust maybe? Or a known issue with the card?
