Strange Temp reading help
1 Dec 2010
North Wales
Hi, I built myself a new computer yesterday and it all went great however i am worried aobut some temp readings that are showing.
The main-board and SYS in is what is worrying me.. Any ideas?
Thanks
Wonky / non-existent sensors and then wonky / non-existent support for those particular functions / sensors from HW / OHW Monitor. It's nothing to be concerned about. On the flipside, sometimes you'll get readings of 0c. The only thing you should be concerned about is the Core #0 - #3 and package temp along with TMPIN0 under GTX 970 and those look absolutely fine.
