Strange USB Problem.
17 Jan 2006
Dundee
I have an ASUS PC here that has a very strange problem.
This is what happens
  • The PC will start when you remove any USB device.
  • It does only happen when the device was attached when the PC was on.
  • This happens on every port.
  • Nothing happens if you insert and remove a USB device
Have checked BIOS and everything is fine. Has anyone come across this before?
The spec is:
Motherboard : Asus P5VD2-VM
BIOS Ver 0402 (4/11/06)
Isn't there an updated version of the BIOS? 06 seems pretty old...
You just beat me to it - found the latest version and installed that and hey presto all is fine.
Was very strange tho. There is nothing mentioned in any of the BIOS updates about this problem.
Cheers for reply. Happy New Year when it comes !
