Streaming 4k
4 Oct 2005
Herefordshire
Hi guys i am after some advice please.
Below is what i use to stream movies and tv series, in the past 1080p and 3d movies has been fine with several people able to accsess the media server without probs.
In comes nice shiny new 4k tv a insurance replacement for my previous tv 1080p tv. i cannot for the life of me manage to stream 4k content it just constantly buffers, plays for a a min or two then buffers. any idea please guys.
All 4k content is stored on the media servers 2tb drive, with the rest on the nas, only i am currently accsessing the media server.
Tv
LG 60UH850V(use plex app for web os 3.0)
Nas
synology DS215j
Network
All 1gb wired network going through a 1gb switch linked to a Asus RT-AC87U
(media server)
mobo
Maximus VII Hero Intel Z97 (Socket 1150)
cpu
Pentium K Anniversary G3258 Socket LGA1150 Processor(overclocked to 4.3ghz)
mem
corsair vengene pro(16gb)
psu
corsiar rs 750 psu
case
corsair Carbide 540
graphics card
nvidia 750ti
drives
2tb drive
500gb drive
os drive
120gb samsung ssd
Thank you
I'd try and isolate the issue to the network, or the set itself .... can you plug a USB pen drive with some 4K content directly into the TV and see how that plays?
Can you stream 1080P to this new set OK?
I dont have a usb pen drive big enough.
and yes 1080p and 3d movies are fine.
cheers for the reply
Is it having to transcode the 4k content?
My plex server cant transcode 4K fast enough to play to the TV. (Old i5 2500K)
Not trying to be silly here, i have no idea, i just installed the plex server and did not alter any plex settings.
How do i find that out ?
haveing the server transcode the 4ks does that mean the tv does not , and if i find the setting to allow the tv to do it wil the tv cope ?
It's most likely that Plex is trying to transcode the 4K content. I don't know where the setting is off the top of my head but you basically need to set it to stream the content direct.
Will have a look from home, but if you go to the webpage of the server, into settings, there should then be a server settings box, and a streaming tab.
That is from memory so might have changed
Kimbie
I imagine the plex client app on the TV has a bitrate limit so it can't direct play from the server because it's 4K.
So your server CPU might be struggling with the transcoding.
just a wee update.
I still cannot for the life of me get the web os 3 plex app to stream 4k content on my tv.
but using the web os3 pic/video app and browsing to the plex server then playing the film it all works ? lol, i have no idea why.
would a anazon fire tv player be a better option ? does anyone use one of these to play 4k content from a server ?. i woudl get one to test but i woudl nto want to waste my money. so if anyone has any ideas woudl be great.
i have dug intot he dlna setting and tried various settings,
mine was initialy set to false for both direct play and direct stream ? is that the ideal setting or do both of them need to be put to true ?
thanks for the advice
See
https://support.plex.tv/hc/en-us/articles/200250387-Streaming-Media-Direct-Play-and-Direct-Stream
What is the server showing
The above shows a Direct Play steam to my Samsung TV (running Plex app), what does yours show?
Thanks
now when i am streaming via the video/pic app on web os 3 it connects to the plex media server and plays just fine. as soon as i try and use the inbuilt plex app no way will it play stable just judders and stutters. so im thinking it cannot be the plex server rather than the plex web os ap ? is there anyone with alg tv with web os 3 ?
cheers
Does Plex Media Player have support for 4K?
Yes! Plex Media Player automatically detects the resolution of your screen and draws the interface accordingly. The app also supports playback of 4K video files using the H.264 (AVC) codec in most containers, so long as your computer is powerful enough to decode it.
Sounds like your pentium isnt powerful enough to decode 4k, so set plex to direct mode.
From plex
If your server isn't powerful enough for how you use it, you will notice playback issues such as stuttering, buffering, or sometimes even an inability to play at all. If this happens, it usually means the CPU can't keep up with the number of users or the amount of transcoding or both. So, you might consider upgrading your hardware. It may also mean that your hardware is fine but your network is too slow.
I don't think the current Plex app on Web OS 3 can do 4k direct play, which is what you need really.
Have you tried X-Play instead? It's on the LG app store so may be worth trying!
I am personally awaiting delivery of an Nvidia Shield TV as well, which should do 4k Direct Play via Plex.
Yes
or a NVidia shield for slightly more money.
Your server looks absolutely fine and you have a hard wired connection so Plex is still struggling with transcoding (unlikely I think, but with big enough files more than possible) or the TV app is just poor (and that would not surprise me one bit).
Also you are using plex and it just loves to transcode and its client can be a bit flakey on some devices.
Try Kodi.
I do actually still have plex and use it for TV but all my high end stuff Blu Rays and 4k I use Kodi.
