Streaming from PC to TV Help please.
18 Jun 2011
Hey all,
Ive been thinking about this for a while and its way out of my depth of knowledge had a quick google but got confused. so here i am !
Im looking for a device ( if one such exists ) that can stream what im watching or doing on the PC to my HDtv.
I enjoy watching starcraft however when a few mates come over it would be so much easier to put it on on my pc and for the picture and sound to appear on my tv.
the tv can not be moved or i would just use a HDMI cable. So im looking i guess for a streaming device. I have lots of movies stored on pc so ideally be able to look at getting them to be able to play on tv from pc.
i looked at the ATV2 jailbroken possible but im not sure if that will help my needs.
Any advice would be great. Thanks
James
do you have a console plugged into your tv? maybe you could stream to that with media center or the likes, I know there is a lot of other progs you could use just cant think of any of the top of my head - pretty sure you can find something.
I have An Xbox plugged in , but what if i want to say stream something from Twitch tv etc
The TV is a fair distance from PC, so ideally like not like to have more cables trailing around my room
Can you run a cable around the room or something?
I don't know much about those devices, but if they run at 2.4Ghz, then that is the same as wireless routers too (do you have one of these) and some landlines phones, and microwaves etc... My point being it may not be a stable signal. Sure it might be great just saying personally I'd try to get a wired solution.
I use some for my sky downstairs so I Can watch it on the tv upstairs wireles and they are on a diff band - 5.8ghz freq, well same kinda thing but mines that.
so ive been looking at the KFA2... yes it seems to do exactly what i want, however... is there another alternative that does exactly the same but cheaper ? Thinking about it i wanted originally an Atv or similar streamer but ive shifted to this as it will do all that from my computer. Thoughts?
KFA2 is the only one I'm aware of. No idea how good it is mind! Unless you really hate cables I'd always find a way to use cables if I can. But that's me.
