**STREAMPLIFY FOR ALL YOUR STREAMING AND VLOGGING NEEDS**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Overclockers UK welcomes a new brand offering you an affordable way of streaming with quality products without breaking the bank. Streamplify is now available to get you going whether you are streaming your gameplay or video blogging.
Streamplify is a brand born from the desire to simplify streaming and make it accessible to all. The internet has become the place to hang out, chat, and play, and Streamplify want to share the joy of live streaming with all. With their high quality, yet easy to use hardware even your Nan could start a Twitch channel.
Streamplify currently offer two different types of Lighting, a Green Screen, a 1080p 60fps Webcam and two varieties of RGB Microphones.
Steamplify offer everything you need to start your streaming career.
For more information please check out our Blog about the brand and products here
products
Streamplify SCREEN LIFT 200cm x 150cm, Hydraulic Rollbar Green Screen @ £129.95 inc VAT
Green screen, 1.5m x 2m, Hydraulic lift, Lockable wheels, Crease resistant, Water repellent, Insert Portable
Built with a large backdrop size and designed for seamless chroma keying, SCREEN LIFT 1.5M allows for more immersive and creative content. With its portable and convenient design, this Green Screen is perfect for streaming, vlogging, photography, video recording, and more.
Hydraulic lift mechanism and lockable foot wheels allow for easy height adjustment, smooth movement, and fast setup.
Only £129.95 inc VAT.
ORDER NOW
Streamplify CAM Full HD 1080p 2.0m Pixel High Quality Webcam for Streaming and Vlogging @ £59.99 inc VAT
Full HD 1080p resolution, 60 frames per second, Privacy slide, All glass lens, Auto-adjust features, Integrated dual mic, Plug and play
Featuring full HD 1080P resolution at 60 frames per second, the CAM delivers crystal clear video quality. All glass lens with built-in smart autofocus captures crisp and razor-sharp video with fast and smooth picture adjustment.
Comes with a lightweight yet sturdy foldable tripod that allows for easy height adjustment (standing height 14.5cm – 21cm).
Only £59.99 inc VAT.
ORDER NOW
Streamplify LIGHT 10" Ring Light, 5V USB White LED - Black @ £19.99 inc VAT
10” ring light, 3 colour temperatures, 10 levels of brightness, Smartphone holder, Camera mount, Foldable tripod, In-line controller
Lightweight and versatile Ring Light delivers optimal lighting for every occasion, making it perfect for streaming, vlogging, photography, video recording, and more. Adjust between 3 color temperature modes and 10 brightness levels to find the perfect look for you.
Includes a portable yet sturdy foldable tripod that allows for easy height adjustment (standing height 20cm – 25cm).
Only £19.99 inc VAT.
ORDER NOW
Streamplify LIGHT 14" Ring Light, 100 - 240V, White LED - Black @ £64.99 inc VAT
14” ring light, 4 colour temperatures, 10 levels of brightness, Smartphone holder, Two camera mounts, Two-in-One tripod selfie stick, Remote control, Tact-Switch control panel
Premium Ring Light delivers studio-grade lighting for your every need, making it perfect for streaming, vlogging, photography, video recording, and more. Adjust between 4 color temperature modes and 10 brightness levels to find the perfect look for you.
Includes adjustable 2-in-1 Selfie Stick Tripod to switch freely and easily between Tripod Stand mode and Selfie Stick mode (standing height 50cm – 170cm).
Only £64.99 inc VAT.
ORDER NOW
Streamplify MIC RGB Microphone with Mounting Arm and Pop Filter @ £69.95 inc VAT
Cardioid microphone, RGB lighting, Included arm mount, Quick mute function, Two audio out modes, Plug and play, 48Hz sound quality
RGB Microphone with a mounting arm that allows for fully adjustable and flexible positioning. Cardioid pickup pattern perfectly captures your voice while blocking out unwanted noise from the sides and rear.
Features 2 audio playback modes, Full Playback Podcast Mode and One-way Playback Gaming Mode, to suit your needs no matter what type of content you’re creating.
Only £69.95 inc VAT.
ORDER NOW
Streamplify MIC RGB Microphone with Mounting Tripod and Pop Filter @ £59.99 inc VAT
Cardioid microphone, RGB lighting, Included tripod, Quick mute function, Two audio out modes, Plug and play, 48Hz sound quality
RGB Microphone with a lightweight yet sturdy tripod that allows for easy angle adjustment and stable positioning. Cardioid pickup pattern perfectly captures your voice while blocking out unwanted noise from the sides and rear.
ORDER NOW
Bundles
Streamplify STARTER Bundle Including MIC TRIPOD, CAM, & LIGHT 10 @ £129.95 inc VAT
MIC TRIPOD RGB Microphone, CAM Webcam, LIGHT 10 Ring Light, High quality streaming hardware, Easy to adjust tripods, Plug and play.
ORDER NOW
Streamplify PRO Bundle Including MIC ARM, CAM, LIGHT 10 and 14 @ £199.99 inc VAT
MIC ARM RGB Microphone, CAM Webcam, LIGHT 10 Ring Light, LIGHT 14 Ring Light, High quality streaming hardware, Easy to adjust tripods, Plug and play.
Only £199.99 inc VAT.
ORDER NOW
Streamplify COMPLETE Bundle Including MIC ARM, CAM, LIGHT 10 & 14, and SCREEN LIFT @ £369.95 inc VAT
MIC TRIPOD RGB Microphone, CAM Webcam, LIGHT 10 Ring Light, LIGHT 14 Ring Light, SCREEN LIFT Green Screen, Plug and play.
Only £369.95 inc VAT.
ORDER NOW
Streamplify HUB CTRL 7 USB Hub with RGB LEDs and 2.0A Charging @ £44.99 inc VAT
Stream deck, 6 x USB 3.0 and 1 x 2.0A, Swappable acrylic icons, RGB lighting, LED indicator lights, 2.0A charging
Only £44.99 inc VAT.
ORDER NOW
Like the look of the screen much better than the springy oval metal fold up ones which often attack you when trying to fold them or wack you in the face.
Please find TechteamGB review:
Overclockers UK video:
I will update with more reviews as they come in over the new few weeks.
Given that identical ringlights are available for about half that price it would be safe to assume that they are over-charging for everything else too.
  • Desk mounted tripods take up a surprising amount of room. On small desks they can get knocked.
  • Mics attached to the desk need **decent** shock mounts, and/or filters (noise gate, noise cancellation) to dampen keyboard sound. Beware, anyone with mechanical keyboards.
  • Greenscreen needs even light, and so does the presenter if desk-based. It'll be hard to balance lighting of the presenter against shadows on the greenscreen without a third light source.
  • Pop-up greenscreen is a convenient space saver, but width limits to how far back it can go based on the resolution being captured on the camera, or the crops applied in the capture (e.g. OBS crop).
looks like it will be OK as a starter pack if you want stuff together in one shot and you have money to burn. I'd want a third ring light included for the price of the full kit. Hard to judge the value of the pack without knowing the quality, it looks more solid than the average kit sold on large online stores, though would compare against equivalents from other vendors before buying.
NEW USB HUB added to the range.
Featuring six USB 3.0 ports and one USB with 2.0A power charging, each support customisable, acrylic icons, so you can configure this hub to best suit your needs. There are sixteen icons to choose from, catering to your every need. Every port has a dedicated power button that is equipped with an indicator LED. Additionally, each of the acrylic icons is illuminated with RGB lighting from LEDs embedded in the casing.
