Hi, ive had the striker 2 extreme board for a month now tweaking away and after much research ive generally found that it has been labelled as a problem board.. I have just managed to get it extremely stable and heres the settings and config etc
1333 linked fsb
ocz reaper x 1333 ram
6-5-5-18 1T
No northbridge watercool
cosmos s chassis
gx9800x2 quad sli
4162mhz core 2 extreme 9650
vcore 1.6
loadline calib disabled
pll 1.5v
vtt 1.32v
mem 1.84 v
nb 1.5v
sb 1.5v
everything else is auto
Im pleased with the overall overclock and stability was assumed after sisoft burn in test x4, pc mark vantage x2, cinebench x 4, in this order without shutdown..
bios 0114 (latest)
the only probs ive had is that i cant shutdown or open programs in windows if the pc has been on for over 5 hours>> without interaction
I would love to get to 1600 fsb but the board/memory is being stubborn however just to confirm these stable settings for profile saving i would appreciate feedback as to how i can fine tune the voltages etc as im pretty sure that there are some settings that ive listed that may be overkill ie vcore??
i use a coolIt elite for the cpu and temps dont go above 52...
i think that this is a reasonable overclock and i would love to start gaming now but i do have the bug and want to squeeze as much as i can out of the system so any advice is appreciated.
1333 linked fsb
6-5-5-18 1T
cosmos s chassis
gx9800x2 quad sli
vcore 1.6
pll 1.5v
vtt 1.32v
mem 1.84 v
nb 1.5v
sb 1.5v
bios 0114 (latest)
No CPU at the moment has such a high fsb at stock, so you can only reach it through overclocking. All 790i ultra (AFAIK - The main ones do) boards support upto 2000mhz fsb providing your CPU and RAM can get there.
