Striker II Extreme BIOS not updating correctly
  • Thread starter Thread starter cje
  • Start date Start date
cje
cje
3 Jan 2009
Hey guys I need some serious help. Whenever I try to update my BIOS using EZ Flash 2 in the BIOS, the erase ROM leaves a small chunk undeleted. The yellow bar skips a bit then carries on as usual. The update then proceeds ok, but I think my BIOS might be corrupted or something, as my windows install and hard drive has crashed 2 times this past week.
I did use ASUSupdate to install the BIOS before, yes I know now that it was a bad thing to do.
I am trying to update it to 1104, but it seems that it might not be updating correctly. I am grateful for any help received. Thanks
The reason why I think the BIOS is not right is that reported voltages are 0.1v higher than set, which is high. And, my windows install has corrupted twice in the past 2 days.
Turn power off at back of PSU.
Press front power button to discharge caps in PSU.
Remove BIOS Battery.
Leave for half an hour.
Insert 1 stick of RAM in slot 3 (3rd away from CPU socket).
Reflash with 0901 BIOS.
Reset cmos after flashing.
OK, ive just taken the battery out. I recently had a corrupted hard drive. You think it could be related to a slightly offish BIOS?
oh - and do I update it 1104 after its updated to 0901 succesfully? Or should I install windows etc with 0901, and try some overclocks, and if I don't see any problems, be happy right?
EDIT - No, it still does that funny skipping in the "loading" bar. It says "erasing", the yellow fills the first 3 blocks, skips three blocks and carries on filling the rest. It seems OK, but is this normal?
Thats normal. Those bits are bits of the BIOS that haven't changed. Think of it in terms of a windows update run. You don't totally reinstall windows everytime you do a windows update if you know what I mean. :)
Cheers Andy. Should I update to 1104 now? Or just install vista etc, get my HDD back up and running and then update to 1104? Or just not bother with 1104 for now, and try to OC with the current BIOS?
try the 0901 first - see how it goes - if its crap then update to 1104. Different BIOSes can work differently with different components.
Golden rule with BIOSes is if it ain't broke, don't fix it. Unless there is a major upgrade benefit in a newer BIOS of course ;)
OK, I've isntalled vista etc. Is the 0901 free from the corruption issues that plagued earlier BIOSes? I don't want my new HDD getting corrupt on me. :D Cheers for your help Andy.
901 & 1104 were the ones I found to be most stable. 1104 gets rid of the 400 (1600) MHz FSB hole at 9X multi.
Best advice I can give is back up all your import data and just have a good fiddle around with them both :D
