BSOD, hanging, memory, cpu, and network adpater issues too!
I have also had loads and loads of issues with this board.
- A large majority of the time I can't even make it to POST, and after serveral restarts (5+) it gets through post. Why does this happen, i have never know a PC to crash before it gets to this stage.
- I have issues with it getting suck on DET IDE.
- Underclocking my memory by loads.
- Making my QX9650 really slow, 50% slower than it should be.
- When setting the memory setting manually, Vista hangs, BSODs etc..
- The latest issue is that the network adapters don't seem to be picking up any network!
The BIOS update I performed last night (902) looks to have solved the problem I was having with the memory issues and the hangs/BSODs, and also my CPU seems to be closely matching the spec found in SiSoft.
So this does improve things slightly. But come to turn on the PC this morning, everything looks to be running fine, but no network!
Have uninstalled the drivers, re-installed, set IP addresses manually, have checked my other networking hardware - but nothing seems to be working!
I think i am going to (at least) put down about ~40+% of the problems to Vista! Therefore I think to solve the latest problem, re-install Vista, see if that fixes it, and if so, then Vista is the culpret, otherwise I am afraid I will be RMA'ing this board.
Matt
