Hey guys, i'll explain a bit before i get to the point... or you could scroll down to the point
I baught a raptor, thought it was broke, done a whats it called so they send me a new one, figured it was a sata 2 raptor so it wasn't broke, stuck with 2 drives, cba to sell one cos known my luck somthing will be "wrong" with it blah....... there we go long story short lol.
My current set-up i have just the one raptor, so i'm wanting to stripe them both, may aswell, it's that or use it as a paper weight.
I'm wanting to know if it's possible to take an exact image of my one drive as it is ( every thing from what mouse icon i have, keyboard key speed settings, my windows XP key, valadation (sp?) etc... ) then format the drives, build the raid, then put the image back onto the disks that was on my original one disk.
So i wouldn't have to change a thing, wouldn't need to buy a new key, wouldn't need to change any settings, every thing... exactly, the same
Is this possible?
Also on a quick question, i'm a nub at raiding, and i see when in the raid options there is a byte size i think it was called? e.g. an 8 / 16 / 32 / 64 byte striped raid? Could somone explain this please.
Thanks guys, much appriciate any response at all
Is this possible?
