One comment. CFA Monitoring.
CFA piling rigs are now normally equipped with sensors to read rotation, rate and depth of penetration, rig torque and pump strokes. This is displayed in the cab so that the driver can control the drilling phase and also the concreting phase. The latter will draw a concrete profile on the screen with tramlines to indicate the nominal size and wavy lines to show the actual profile in the ground. These should always be on or outside the tramline to indicate a good pile. Where they are inside the line it indicates necking.
By knowing the volume of concrete per pump stroke and the rate of auger extraction, the section of the pile at any depth is calculated. As the client, you should obtain printouts for each pile from the site managers laptop.
350 diameter piles are skinny and 20m (60 diameters) will be the limit. 400 or 450mm will produce shorter piles but be more expensive in concrete.
Good luck.
