Struggling with M-itx motherboards!
Ahh thanks for your help, I trhink I might go with the NH-U9B SE2 considering as per that handy chart it doesn't have any issues with the GZ77n-wifi and the layout doesn't seem to have changed for the G87n. Seems like a strong performer!
The low profile Noctua L9i is surprisingly good. If you're not overclocking as far as the CPU will go, it's a good option.
How about turning all this on its head. If you're looking at a Prodigy build, which frankly is so big it defeats the point of "small form factor", then why don't you consider a Silverstone Temjin TJ-08E?
It's the same size as a Prodigy but supports Micro ATX boards, which instantly opens up the playing field. No more Mini ITX premiums so boards are a bit cheaper and more plentiful, plus you have the AMD option too (although why would you want to I don't know).
What did the OP end up with in terms of cooler on his Z87N-WiFi. I have a Z87N-WiFi in my build (build specs in another thread) but bought the Haswell retail package so currently rolling an Intel cooler.
I will be buying an aftermarket cooler so would be interested as to what you find fits on the board, as well as PCI-E and RAM clearance. Ideally I'd like a 212 Evo but I'm sure it may have size issues.
