- 5 Apr 2004
My MSI Mortar b350 with a 2700x is stuck in a boot loop, where I don't even see it post.
The machine comes on, with fans spinning, the diagnostic CPU led flashes and it then seems to restart. The screen doesn't show on my monitor so presumably nothing has posted.
Changes i've made recently. I updated to the latest bios for the motherboard, it was advertised as beta........... I suspect this might be the issue. I've used the computer for about a week since doing this.
Yesterday I started to get a windows error when booting. It would go straight to an error screen during booting. Doing a restore to a few days ago, seemed to fix this, I suspect something to do with booting was becoming corrupt.
Finally just before this all happened, I was playing around with trying to make a Windows USB image, so that I could try repairing the OS. It turns out I didn't have a large enough USB key to hand, so I set windows to do an upgrade. I figured this might repair whatever was broken and worse case I might lose a few settings. After that the computer hasn't posted since.
Things i've tried to diagnose.
Unplugged all hard drives and tried booting
Unplugged graphics card and tried booting
Removed CMOS battery and shorted jumpers various times
Put a USB key with a bios file in and tried botting
Removed CPU and tried booting
None of the above helped and confirmed that the issue isn't something that Windows did.
My conclusion is the bios is buggered.
What do you think and do you have any suggestions to fix it?
