Stuck on Crysis - bug?
20 Nov 2005
Birmingham
Okay - am at the bit in Crysis where you have rescued the first scientist in the first large emcampment.
You get the scientist and your mate then says go and destroy the enemy tanks. Well I have - there were two. I have also killed every enemy in the camp, and now.... nothing. What happens now. I have not been given another mission objective or anything and my mate has sodded off with the scientist.
Have I missed something or is this a bug?
No that's right, you kill the two tanks and then when your mate takes the fit bird away you have to leave the encampment and go all the way through the hills to rendevous with Prophet. It should be on your MAP/PDA thingy as a green dot quite a fair bit away.
There is a bug there.
One of the objectives doesn't always get triggered off, you have to make sure you approach the area from the front, rather than sneaking in the side on a boat or something if I remember correctly.
The problem is just caused by the position of a trigger that sets off an objective as far as I can tell.
Cheers for the responses guys. Yea - took to exploring MMO style and found the way up the waterfalls to follow the river. Was not obvious though and I did not trigger the mission so it was a bit hard to know which direction I should go.
Got there in the end.
