stuck on HL2 ep1 - help...
5 Jun 2005
Southampton
ok i'm a water filled area and the door is locked, one end has a 'power switch' and when you press it the door opens, however i can't get to the other side as the water has electric pumping into it.... so how do i make it across?
Was stuck on this exact part earlier myself mate!
As said above, place the barrel under the walkway that's fallen down, you can then jump the remaining two parts to the door.
ok to stop the walk way dropping yeah? - but what about the other side can that be jumped in one?
Yes it can, took me a few attempts mind you.
