I can't for the life of me understand why complicating the problem with unnecessary equations and factorisation. I gave the solution in post 2, using basic trigonometry.
Probably because you didn't give the solution... After he's split it in the second diagram the only angle you know on the right hand side triangle (for which you have the actual length value you suggest to use) is the 90 degree... what you suggest with reverting to "basic" trig with one angle and a side only works because for a right angle triangle the 90 is a given - for your idea you would need to use another angle other than the 90 (Either C, or A - 30) to solve the green line, which you don't have.
