Im drunk so lets get this straight..
The case has two fans fitted (although specs suggest it should only come with one).
These two fans are 3pin and not 4pin PWM type.
You can plug a 3pin fan onto a 4pin fan header, there is a little plastic tab on the header that is "offset" to oneside.
