Do you have fast sync enabled?
How can i check and if so disable it?
Could my issue be releated to this:
https://forums.overclockers.co.uk/showthread.php?t=18740161
My 1080 is Gainward Founders
What OS are you running ?
If you are having dpc latency issues place your windows power management to high performance until nvidia release a fix for this ...
nvidia are aware of the latency issue
Im on Win 10
What will high performance power management do?
Its the power features of windows balance uses less power speedstep ect there is more too it re power states ect...
Well for me running on win 7 in balanced power settings i get really bad dpc latency with the 1080 once i set too high performance no issues..
give it a go at least select high performance then try the game that have the issues see if it solves it ?
windows search power should bring up your power options
there is allso a thing called cpu unparking not sure if your cpu parks though try the power setting 1st
Power settings changed seemed to work, thanks
I assume this will be addressed by Nvidia in driver update hopefully soon?
Well done Harney and good work![]()
