sorted (Cooler Master GX 650W '80 Plus Bronze' Power Supply) sounds like it, get the temps better with a better cooler and you wont have the problem, was asking for the psu type as some have fans that blow straight onto the cpu, which under high load can heat it even more not cool it dependant on psu etc, as your case is a top psu mounted one im guessing as cant tell really for the pic's.
just guess work tbh. but cpu cooler like mentioned above would solve it short term.
from most of the reviews and comment i can find from other forums, seems to be a few that have heat and more loud that it should be issues with it, but warranty is good and does give constant power, but a high number of RMA on a few sites i've looked it, can't link either as other shops and forums, coolmaster not really known for there psu
