Stylish cases that accept 280mm aio in top
28 Oct 2002
Hiraeth
Hey all,
I've got a x62 from NZXT and am struggling to find a decent case to use it in. I don't think the tubing is long enough to fit the rad at the from, so I was going to mount it at the top of the case. The only issue is that most only cater for a 120/240 set up.
Are there any decent cases that I can order today that will allow me to fit the x62?
Bonus points for orange accented cases and really want a windowed case as it's going to sit on my desk.
What budget have you got? I have recently used the Lian Li PC-011 Dynamic with the X62, and it did fit well on the top. If you want can attach a pic of how it turned out
That would be great thanks. Looking to spend about £100 although more for the right case.
