** STYX IT TO THE MAN WITH RAIJINTEK!!! **
OcUK Staff
26 Nov 2014
Stoke
Introducing the Raijintek Styx, a Micro-ATX version of the Metis with dual 240mm radiator support, 280mm VGA support, 180mm CPU Cooler support and more. Like the Metis, the Styx has an full aluminium exterior with the same finish and looks superb in the flesh.
The Styx is available in 6 colours, both in a windowed and 'classic' non windowed version. Stock is due to arrive in October and will be limited for the first delivery!
Raijintek Styx - Windowed - Black Micro ATX Case @ £64.99 inc VAT
STYX, RAIJINTEK's new aluminium Micro ATX case, has a remarkably elegant appearance and expansive compatibility with your PC system. STYX is compatible with standard ATX Power supply, max. 280mm VGA card and 180mm height CPU cooler.
STYX also provides a great cooling solution, with a 120mm fan pre-installed at rear, optional 2*120mm fan on top /side, optional 120mm fan at bottom and max. 240mm radiator cooling on top/side. Moreover, STYX offers a drive bay for Slim DVD on the side of the case.
With an entirely black coating inside and attractive aluminium colour hair-silk anodized appearance, the STYX satisfies not only your requirement for an elegant chassis, but also offers plenty of features and expandability too!
Features
- Aluminium colour hair-silk anodized appearance design
- Internal coated black throughout
- Compatible with ATX POWER SUPPLY
- Compatible with max. 280mm VGA card
- Supports up to max. 180mm height CPU cooler
- 2* USB3.0 ports
- Anti-vibration rubber for HDD installation
- Supports 3* 3.5"HDD +2*2.5"HDD/ 1* 3.5"HDD +4*2.5"HDD
- 120 mm performance fan pre-installed at rear
- Option to install 240mm radiator on the top/side and 120mm fan at bottom
- Large zone of ventilated holes for airflow on side panel
Specification
- Colour: Black - Hair-silk anodized
- internal color: Matt Black
- Dimension (D/W/H): 360mm*210mm*335mm
- Weight (N.W.): 3.8kg
- Weight (G.W.): 5.2kg
- Material: Alu. 1.5mm (external), SPCC 0.5mm (Internal)
- M/B Type: MICRO ATX/Mini ITX
- Power Supply: PS-2
- Power Supply Integration: ATX PSU; Vertically at bottom
- 5.25" Drive Bays: Slim DVD*1
- 3.5" Hidden: 1+2 (exchanged 2.5")
- 2.5" Device: 2
- I/O Panel: USB3.0 * 2; HD Audio x 1
- PCI Slot: 5
- CPU Cooler Height: 180mm max
- Graphic Card Length: 280mm
- Side Panel Style: Transparent Window
- Cable Management: Regular
- Front Cooling Fan: n/a, Rear Cooling Fan: 120mm*1 (pre-installed) , Left Side Cooling Fan: 120MM*2 or 240mm radiator (option) , Top Cooling Fan: 120MM*2 or 240mm radiator (option), Bottom Cooling Fan: 120mm*1 (option)
Only £64.99 inc VAT.
ORDER NOW
Raijintek Styx - Windowed - Red Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Silver Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Blue Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Gold Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx - Windowed - Green Micro ATX Case @ £64.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Black Micro ATX Case @ £62.99 inc VAT
Features
- 2* USB3.0 ports
Specification
- 2.5" Device: 2
- PCI Slot: 5
- Side Panel Style: Vented
Only £62.99 inc VAT.
Raijintek Styx Classic - Red Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Green Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Blue Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Gold Micro ATX Case @ £62.99 inc VAT
ORDER NOW
Raijintek Styx Classic - Silver Micro ATX Case @ £62.99 inc VAT
ORDER NOW
do they leak like the AIO CPU watercoolers that Raijintek produce, and then refuse to help customers afterwards?
Lol this tbh, very unimpressed over Raijintek's perceived response to what is clearly a fault with their cooler.
I would avoid them like the plague.
They look like really nice cases but you can't deny that Raijintek have damaged their brand slightly with how they have handled the cooler issues.
The STYX looks awesome in my opinion. I'd go for the black or silver if I was gonna do a build in one.
Really liked the Metis but unless I was building a HTPC I don't have need for a mITX rig.
(and as previously mentioned, keep it on topic!)
Looks pretty good - small window though...... must be designed for modest people to show off some of their components!!
looks like a nice little case.. even though its a small window. must be one of the few that has a window on the right.. :) if only it was a couple of months back I would have bought one
This is Great news "ChugNorris" , I will be ordering Black with window & be doing another
Raijintek Build in Case Project Section , After all i will "STYX IT BEING THE MAN WITH RAIJINTEK!!! " (Will not be drilling or Cutting in this Build)
My Raijintek Metis - Silver Mini ITX Case Build
Still saying on pre-Order ?
They're expecting delivery in October I believe. So it's preorder until then I'd guess. I'm keeping a close eye on this one to replace my Prodigy M (which I've decided is too flashy). Very much enjoyed your Metis build!
ote1 Yep ,Looking forward to this Case :)
Put a thread up in case central for discussion. Only found this thread/news by accident as in the last few days I've been scouring the internet for mATX cases and this happened to be released. :)
These do look really nice, the top vent should sort out the cooling issues that the itx version has, but still looks like its going to be a hot box! Good thing its made of metal then I guess so it can be its own heatsink.
They look nice for sure.
One flaw is the size of window, as it was mentioned already.
But will be ok for ITX users.
I wanted to use Phanteks case for my next rig, but this one looks better, with reverse motherboard layout.
Now, which colour should I choose.... :)
