Subnet masks
28 Dec 2007
Sheffield
Ok I need some help with this work for my college course. Below is the question:
Number of needed subnets 2
Network Address 195.223.50.0
Address class: C
Default subnet mask: 255.255.255.0
Custom subnet mask _______________________________
Total number of subnets ___________________
Total number of host addresses ___________________
Number of usable addresses ___________________
Number of bits borrowed ___________________
What is the 3rd
subnet range?
What is the subnet number for the 2nd subnet?
What is the subnet broadcast address for the 1st subnet?
What are the assignable addresses for the 3rd
subnet?
As you can see I've worked out the class and default mask, but from here I am completely stuck.
Could somebody please help me through the steps of working it out? (Note: I'm not asking people to do my homework, this is the first question and once I have an example of how to work it out I'll do the other 14 questions myself)
Thanks a lot :)
Its actually really easy.
You want 2 subnets so its a 25 bit net mask, you are borrowing 1 bit from the 4th octet.
the first network will be 195.223.50.0 and the usable address range in that subnet is 195.223.50.1 - 195.223.50.126...
I'll leave the rest for you ;)
It could also be a trick question, as the above will only give you 2 subnets but the bottom of the question talks about a 3rd, so you will have work it out for 4 subnets instead.
obviously you cannot make 3 subnets, 4 is the closest to it.
Thanks, but still not getting it :(
I feel proper stupid, been reading for past 2 hours + almost everyone in my class gets it, except me :(
