Subwoofer Advice - Old System
9 Feb 2009
Up North
Looking for any advice that can be offered.
After a long renovation spate at home (for some context, moved house nearly 5 years ago, built a rear extension and have been living in the back of the house, decent room with kitchen & living area and a full Sonos setup, thus comfortable).
Since then the Lounge became a past thought for a while, but we have now brought the room back to use, new sofa, new TV etc., so I have dug out all my old audio gear - a Yamaha RX-V375 and a Monitor Audio Vector kit......only issue is the sub has cooked itself, bass tone when turning on, and a fishy electrical smell, so certainly something amiss.
Looking to replace the sub - any recommendations? Happy with buying used as well if there are any particular standouts.
FYI - the sub with the Vector kit that I have (now non-working) is the Vector VW-8, was good, but it would be great to get one with a bit more punch.
Thank-you for any help all.
Absolutely, categorically BK.
My Gemini ii, bought in 2009, needed a replacement power board in 2021. They replaced it without fuss and all I paid was the shipping (£23) & part cost (about £14).
We had a similar spare of renovations and I bought 2x P12-300SB-PR for the new lounge.
The new XLS300 starts at £380 - I'd seriously consider looking there: https://www.bkelec.com/HiFi/Sub_Woofers/XLS200.htm
Can't complain on finish on the subs but electronics seem a bit unreliable but at least UK made, and affordable and possible to repair unlike class D.
I did consider BK if they branched out into 15"+ models I'd have considered them for the HT.
Don't need a sub for the upstairs PC system but gem/xl200 would be fine, for close monitoring use prefer sealed box. I do have a 10" THX ported sub I could use hehe it's a bit big and overkill
Good to hear decent support as well from BK.
Another vote for BK. I've got the XLS300-FF and it's a great sub, goes low enough to pump vibrations through you. I went for a Grade "B" from their eBay store and it arrived completely mint for £338.86 + £10 postage.
Mine is a similar size room, 21.5m², with the volume being 64.5m³ (3m ceilings) and I'm only running it at around half power. I was also considering the SVS SB-1000 Pro, which PT have in at a discounted £549 at the moment, but it's hard to beat the XLS300 where you can save £200.
Bk even more sold to me, thank you. Going to have a close look and as above will look at B Grade as well.
