I doubt a 6.5" driver will go as low as 30Hz, probably 45 at best. OP you can grab an enclosure online or build one if you fancy a DIY job
If my headphones can go down to 5Hz then I'm sure a 6.5" sub can if it's good enough
It'll vary a lot depending on budget though I would guess if its anything like headphones!
It's entirely dependant on the enclosure. With the most common type of enclosures (infinite baffle or reflex) a 6.5" sub isn't going to be useful anywhere near that low a frequency unless it has an insane amount of throw. For these basic enclosures bigger is generally better for the driver in terms of output at low frequency.
If you want an upgrade this is the way to go, I had one in my old A3 loved it...
http://www.dizzythedog.com/index.php?f=data_audi_a3_stealth_sub&a=0
Perhaps you should enlighten everybody with your research then instead of sounding like a knowitall? Its generally accepted wisdom and the reason you don't find many 6 inch subs. People don't want to faff with building transmission line boxes just so they can demo their 6 inch sub, so the trade off is larger cone area.
I have to agree with 18s and dance music, they are fine. I fitted 4 into a smart car back in 2002. Anyway, I digress. The original question is related to confusion, where the op is looking at speakers not subs.
