I got a great little system for my box room.
AMP= Sony TAFE370 (£110)
SONY TAFE370 AMPLIFIER SPECIFICATIONS
Inputs: 1 x MM phono, 3 x line level, 2 x tape loops, tape monitor switch on front panel
Outputs: Headphones, switchable speaker output
Controls: Bass and treble controls, loudness control, source direct
Record out selector: No
Amplifier power (watts): 70 / channel (4 ohms DIN)
Supplied accessories: Remote control handset with batteries
W x H x D (mm): 430 x 135 x 310
Weight (kg): 5.5
Finish: Black or silver
Then I picked up some Sony bookshelf speakers which are incredable for £50.
Specifications
Bookshelf speaker pair
Power handling capacity 120 W
2-way speaker, 2 speaker units
Frequency range 60-50,000 Hz
Nano-fine tweeters
Magnetically shielded speakers
160 mm speaker unit + 25 mm Balanced Dome tweeter
Closed cabinet
Wooden cabinet
Detachable grille nets
Screw type input terminal
£180 and not bad little setup ... for the cash.
I run my TV, xbox360 and PC through it....
PS- use froogle to these items if you wish as they are from competitors:
www.froogle.co.uk
