Hello,
I was looking for some advise on what to do, i have a gaming computer which is about 4 years old now, my current setup can run games like CSGO fine at 200 FPS however with the new generation of games its really struggling and rainbow six siege on the lowest settings is dropping FPA quiet often.
i have attached below my current setup, what i want to know what should i upgrade? i was thinking of upgrading the RAM and also the graphics card (nvidia gtx970?)
what would you do, what needs to be upgraded. or should i look at a whole new PC and sell this one off?
Thanks,
Gamer Infinity i7 DDR3 Configurator (NO MONITOR)
*BASE_PRICE: [+535]
CAS: Antec P183 Advanced Super Mid Tower Black [+92]
CASUPGRADE: NONE
CS_FAN: 3 x 120mm Silent Case Cooling Fans in key area for selected case for ultra silent operation [+25] (500-1,200 RPM SHARKOON Silent Eagle SE 120mm Modular Fans with Dimple Surface Blade and Twister Bearing 8-14 dBA (Custom PC Award Winning !!) [+14])
CPNR1: Cyberpower Sound Absorbing Foam -- reducing audible noise transmitted through solid case panels by up to 75% [+19]
CPNR2: Cyberpower Anti-Vibration Fan Mounts -- reducing the noise generated from Fans [+5]
CPNR3: Cyberpower Power Supply Gasket -- reducing the noice generated from Power Supply [+3]
CPU: (Quad-Core)Intel(R) Core(TM) i7 920 @ 2.66GHz 8 MB cache LGA1366 ***Overclockable XXX***
CD: (Special Price) LG 22X DVD+/-R/+/-RW + CD-R/RW DRIVE DUAL LAYER (Black Color)
CD2: (Special Price) LG 22X DVD+/-R/+/-RW + CD-R/RW DRIVE DUAL LAYER (Black Color) [+16]
CABLE: None
EXPAN: NONE
FAN: CoolerMaster V8 Gaming CPU Cooling Fan (Extreme Silent Operation at only 22dBA + Overclock Proof) ***Overclockable XXX*** [+49]
FLASHMEDIA: INTERNAL 52in1 Flash Media Reader/Writer [+6] (BLACK COLOR)
FA_HDD: None
FLOPPY: NONE
HOMEINSTALL: NONE
HDD: Extreme Performance (RAID-0) with 2 Identical Hard Drives [+21] (2TB (1TBx2) SATA-II 3.0Gb/s 16MB Cache HDD [+48])
HDD2: NONE
IEEE_CARD: NONE
KEYBOARD: NONE
MOUSE: NONE
MOTHERBOARD: Asus P6T Deluxe V2 Intel X58 Chipset SLI/CrossFireX Mainboard SAS Triple-Channel DDR3/1600 SATA w/ eSATA,Dual GbLAN,USB2.0,IEEE1394a,&7.1Audio ***Overclockable XXX*** [+80]
MEMORY: 6GB (3x2GB) PC12800 DDR3/1600mhz Triple Channel Memory [+82] (Corsair XMS3 w/Heat Spreader ***Overclockable XXX***)
MONITOR: NONE
MONITOR2: NONE
MODEM: NONE
NETWORK: ONBOARD 10/100 NETWORK CARD
OVERCLOCK: No Overclocking
OS: Microsoft(R) Windows(R) 7 Ultimate [+128] (64-bit Edition)
OS_UPGRADE: None
POWERSUPPLY: Corsair Power Supplies [+66] (1,000 Watts HX1000W Power Supply - Quad SLI Ready [+96])
PRO_WIRING: Professional Wiring for All WIRINGs Inside The System Chassis with High Performance Thermal Compound on CPU [+11]
RUSH: NONE
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: NONE
TEMP: NONE (AS SHOWN)
TVRC: NONE
UPS: None
USB: Built-in USB 2.0 Ports
USBHD: NONE
VIDEO: ATI Radeon HD 5850 PCI-E 16X 1GB Video Card [+169]
VIDEO2: NONE
VIDEO3: NONE
VC_PHYSX: None
WNC: NONE
WAP: NONE
WEBCAM: NONE
WARRANTY: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE
Thanks,
*BASE_PRICE: [+535]
CASUPGRADE: NONE
CABLE: None
EXPAN: NONE
FA_HDD: None
FLOPPY: NONE
HOMEINSTALL: NONE
HDD2: NONE
IEEE_CARD: NONE
KEYBOARD: NONE
MOUSE: NONE
MONITOR: NONE
MONITOR2: NONE
MODEM: NONE
OS_UPGRADE: None
RUSH: NONE
SPEAKERS: NONE
TVRC: NONE
UPS: None
USBHD: NONE
VIDEO2: NONE
VIDEO3: NONE
VC_PHYSX: None
WNC: NONE
WAP: NONE
WEBCAM: NONE
Just to mention you might want to remove the competitors name
