meansizzler said:
Try putting in a 130Watt Penitum D..., then tell me if you still agree with that statement of yours....I'd like ot know what Heatsink you owuld use, and how LOUD it is...Athlon X2's run pretty quite with 55 Degrees full load on stock heatsink, but put a pentium D in there with Stock Heatsink then you will be at 62 Degrees load and 45DB of NOISE!!!..., not a lot of Heatsinks that fit in that case to handle a Pentium D, not Tried the Zalman CNPS8000, but all the heat being blown around the motherboard can't be good for it, especially the voltage regulators...
You never listen, your the only person who has issues, so what your Processor outputs that, my 3ghz 3700 will be getting close.
Raikiri has a 160w+, closer to 170w really with no issues. Your cooling sucks, you made a big mistake and everyone says so. You can't run a cooler passive when it was designed to have a fan, using the PSU fan is not an option.
I am using a thermaltake Blue Orb II at 60% then speeds up at 50deg to keep it below that level.
Cools fantastically, yours is the only Sugo that does not cool well as you have no clue about cooling, as has been proven in about six threads by different members now. The sugo cools brilliantly especially for a SFF case.
Your processor being 130w as you keep on saying means next to nothing, just means it runs comparatively hotter to a AMD, but on the same scale my 3700 would be around 50 load as a P-D.
Raikiri said it best, you have a 130w processor, its not an excuse, he has a 160w one cooler.
WJA96 ran EE versions of the processor overclocked, got to be hitting over 180w output, and cooler than your PSU cooled cooler.
Sugo's cool great, your cooling solution is crap. End of.
My money is on give me the choice of three fans, a CPU cooler and PSU I could nock 20deg of your temperatures, without much thought.
Oh and the motherboard I used is a Asus A8N-VM CSM Micro ATX (Socket 939) PCI Express Motherboard from OcUK.
Good board, someone sent me a BIOS over MSN, its a great clocking board to which surprised me, as I literally went ennie meanie miney mo.
