- 11 May 2006
Hi,
When selecting a large numbers of units I find that my frame rate plummets, sometimes even as low as half the fps I get when units are not selected.
From experience with the orginal SupCom I knew it was because of the weapon range overlay that shows up for every unit. In the original SupCom it's not usually a problem because the range indicators (red circles) only show up when things like artillery and other fixed defences are selected, but with Forged Alliance it shows up for all units. You can disable this weapon range overlay (in the new overlay options menu) but it disables it for everything, i.e. even if you select an artillery piece the range circles no longer show up. I quite liked that feature in the original SC because I knew where I could fire my artillery, but now I can't ... that or I live with the huge fps drops when select large groups of units.
Any ideas? Can I disable overlays triggered by selection, only for units and not weapon emplacements (e.g. artillery)?
BTW, does anyone know why you get the huge fps drops when viewing weapon range overlays? Is it a normal thing? I have a HD4870 with C2Q @ 3.4ghz.
		 my FPS are almost identical with AA to what they are without AA.
