Wondering if you can get problems from super insulating a fridge freezer or freezer by adding like 50mm of fibre glass type insulation around the base, sides and top. My electricity bill is as high in the summer as winter, and obviously the lights aren't on as long. The fridge walls feel cold to the touch, so there could definitely be improvement. Will be keeping the back clear, and not using much polystyrene. Expect won't be able to improve the door much, except by adding polystyrene blocks inside.
Issues I was thinking of are dampness, compressor getting stuck because not used much, hot and cold spots inside.
