Supermicro IPMI
1 Nov 2007
England
I've just got my first dedicated server and I want to install FreeBSD on it but I'm slightly confused as to how to go about doing so. This is the screen I am trying to use:
If I click save or mount not much seems to happen. To be honest I'm not sure what I am doing.
If someone could give some tips I would really appreciate it!
not used supermicro but is there any option on virtual media tab to mount an iso from your desktop pc?
If wanting to use cd-rom option then you'll need to have it on some sort of NFS mount or similar.
Other option is to find something like remote console and it might have options for something like 'KVMS' -> Storage where you can likely mount an image from your local PC and then change the BIOS to book from CD which will be passed through.
